| but it is interesting. what did your o2 reading do when you introduced propane as suggested? rather than do that you would pull the O2 's and install new ones? I also commented the injectors can be bad although they "test " good. Use a logical approach, ruling things out one at a time. replacing parts without a reason gets frustrating and expensive. good luck.
